Michelin PR3 Review
Re: Michelin PR3 Review
Postby Unity » Sun May 27, 2012 8:33 pm
Traveling with tools and luggage, 38-42 to 40-44. Short jaunts, the former. I don't go quite 200-210 in gear, maybe 195-200. By the way, I'm real happy with my PR3s.
Postby henwin » Sun May 27, 2012 9:42 pm
Unity wrote:Traveling with tools and luggage, 38-42 to 40-44. Short jaunts, the former. I don't go quite 200-210 in gear, maybe 195-200. By the way, I'm real happy with my PR3s. --John
Thanks.
I normally tip the scales at about 190, but by the time I have my gear on and the tools/camera in the trunk and my water cooler on the rear seat, when I clamber aboard, the bike will gain an additional 210, if not 215 lbs.
Postby howardenichols » Thu Jul 26, 2012 9:33 am
Now I've got PR3 on both wheels so I'm curious what air pressures--the big people--are running? By big people, I mean those of us who weigh 200-210 lbs fully dressed (ATG)
"Big" is in the eyes of the beholder. I am interested in advice on inflation pressure for PR3 for my idea of big (I am closer to 250 right out of the shower and then I like to ride 2-up with my wife whose weight I won't divulge but she is not petite).
I changed out my front stock tire about 4K miles ago with the PR3 and then replace the factory original rear tire yesterday (after 9K). Another question: I figured out that the rear tire was gone via the wear bars (and advice from Bob's) but when I got home I decided to check the front time and for the life of me I could not find any sign of a wear bar on that tire. Since I only got 5K on the original front tire and i have 4K on the PR3, I would not be surprised if I don't get the 10-15K that everyone else is talking about. AND 2 things I don't skimp on tires and brakes -- I just don't want to take chances.
2011 R1200RT
2003 Honda VTX 1300
howardenichols
Postby ERC Scott » Thu Jul 26, 2012 11:04 am
Howard wrote:Since I only got 5K on the original front tire and i have 4K on the PR3, I would not be surprised if I don't get the 10-15K that everyone else is talking about. AND 2 things I don't skimp on tires and brakes -- I just don't want to take chances.
Same here. Unless I have to replace due to an early-mileage puncture, I'll replace both tires at the same time. As for what tire pressure to use, assuming your total weight is within BMW's recommended carrying capacity, why would you not go with the recommendation in the owner's manual? As I understand it, both over- and under-inflation can have significant effects on handling and traction (and safety).
Scott
Postby howardenichols » Thu Jul 26, 2012 6:49 pm
Thanks Scott. Your suggestion makes sense.
2011 R1200RT
2003 Honda VTX 1300
howardenichols
Postby henwin » Mon Jul 30, 2012 10:31 pm
Same here. Unless I have to replace due to an early-mileage puncture, I'll replace both tires at the same time. As for what tire pressure to use, assuming your total weight is within BMW's recommended carrying capacity, why would you not go with the recommendation in the owner's manual? As I understand it, both over- and under-inflation can have significant effects on handling and traction (and safety).Scott
While I'm not going to argue with what you say, Scott, I think the pressures called for in the manual are a bit on the "soft" side at least for my RT, and not for just the stock tires, but almost anything else as well. I asked the boys at Bob's and they told me (for the 1200RT) to run 40/42. So that's what I've been doing. I ran my Metzler Z6s at 36-38 and 40-42, and got nearly 11K off the last rear! On the front I got "only" something over 9K. Still not bad. I think the PR3s will do better for me...but as you say, the mileage isn't really a factor when it's time for new shoes. If it's time, it's time. Just for your info, Howard, I'm 6'2" and weigh about 190 wet. ATG, I'd guess I'm pushing 210-215.
Postby R4R&R » Fri Aug 17, 2012 10:08 am
I've made it past 10,000 miles on my rear PR3 so for that, I'm happy (It's been a while since I've had a rear tire go over that threshold). While the handling was good, it seemed like lately I've been feeling occasional slips when pushing medium-hard in the corners; probably an indicator the tire was near the end of it's life. I ordered a new one and hopefully it will be here Monday so it looks like I'm giving the PR3 another try. So far the front PR3 is wearing good, with over 8,000 miles and lots of tread left. Previous to the PR3s, I liked the traction of the Dunlop Roadsmart but typical of Dunlops, their front tires seem to cup prematurely.
'17 Triumph Explorer 1200
'04 R1150R (gone but not forgotten)
('13 Triumph Speed Triple - sons bike)
Itchin' for a ride
R4R&R
Postby grownup » Sat Nov 24, 2012 11:24 am
I love the p3 tires. I am on my second pair. The first set had no cupping on my front after 10K miles. Of course, I was using dynobeads in the tire. This time I am using regular lead wheel weights.
I get about 10-12K on my R1150-RTP with these tires and they are pretty stable tires. However, I found the Avon ST more stable. But, Avon tires are softer and cupped at about 5-6K for me.
Ted
2002 R1150-RTP
2013 R1200 GSA
2016 S1000 XR ( 1 BTC Bike )
grownup
Postby henwin » Sat Nov 24, 2012 1:31 pm
grownup wrote:I love the p3 tires. I am on my second pair. The first set had no cupping on my front after 10K miles. Of course, I was using dynobeads in the tire. This time I am using regular lead wheel weights.
I'm running PR3s now, but some years ago I had a set of Avon Storms on and while they were very good tires--particularly in the rain--they only lasted about 7000 miles--which was way less than I was wanting :( --and then wore out very quickly in the last 100 miles or so. As I recall I was down to the belts on the rear when I replaced them. I'm very happy w/ the PR3s so far...about 5000 miles.
Postby BMWGirl » Sat Nov 24, 2012 7:28 pm
I'm on my second pair of PR3's for this year and the first set had a little over 13K and this set has roughly 8K on them and are still holding strong. I really do like the Michelin tires. :D
BECAUSE I CAN!!!
IBA #37898 - IBR - 2017 IBA #565 Woohoo
2015 R1200GSA white w/PURPLE :-)
'10 K1300GT
'05 R1200ST
"Riding is about having an adventure - you just go with it and No Whining!" Kermit
BMWGirl
Postby henwin » Sat Nov 24, 2012 11:36 pm
BMWGirl wrote:I'm on my second pair of PR3's for this year and the first set had a little over 13K and this set has roughly 8K on them and are still holding strong. I really do like the Michelin tires. :D
What tire pressures are you running? (I'm just curious)
Postby BMWGirl » Mon Nov 26, 2012 7:44 pm
Oh Henry - you strain my brain. :lol: IF I REMEMBER correctly.... 39/42 - I THINK. I know it's close to those numbers. I can check again, the next time I ride. I don't usually commute on it so it may be a couple of days.
BECAUSE I CAN!!!
'10 K1300GT
'05 R1200ST
BMWGirl
Postby henwin » Mon Nov 26, 2012 11:49 pm
No problem, Tina. I'm just curious. Don't strain too much! :lol:
Postby grownup » Wed Nov 28, 2012 10:14 pm
I talked to the sales reps at the BMW MOA Rally in MO. They said the P3 tires work best with the recommended pressure. On my RTP with the Avon ST I ran them harder, but with the P3 I don't need too. I put 37PSI in the front and 42PSI in the rear.
Ted
2002 R1150-RTP
2013 R1200 GSA
grownup
Postby henwin » Wed Nov 28, 2012 10:39 pm
grownup wrote:I talked to the sales reps at the BMW MOA Rally in MO. They said the P3 tires work best with the recommended pressure. On my RTP with the Avon ST I ran them harder, but with the P3 I don't need too. I put 37PSI in the front and 42PSI in the rear.
When they said the "recommended pressure", what pressure were they referring to?
The reason I ask is that on the web site, it doesn't say. It seems to me that I called and asked and then the rep said to run at the same pressure that BMW recommends for the OEM tires, which I thought were very low...like 32F and 36R. I was told by the tech at Bob's who put them on, to run at 40F and 42R, which seemed awfully hard to me, but it's mostly what I do. If I want a bit more traction, I let a couple of pounds out of each. So I'm really curious to know if I'm running them too hard, and if I could get better traction by dropping the pressure, without losing too much wear, and if so, to what?
