Recommended crash bars for 1200GS
Postby Genen8kua » Fri Jan 27, 2012 9:38 am
I'm contemplating adding crashbars to my R1200 GS which already has the bmw aluminum cylinder head guards. Not looking to get the bike into major off-road mode, but want some addl protection and maybe a mounting point for auxillary lights. Do not want to have to remove the things for routine maintenance like valve adjustments. These SW-Motech bars look like a reasonably good value for the money. Thanks in advance for the advice.
Re: Recommended crash bars for 1200GS
Postby Maria V » Fri Jan 27, 2012 10:23 am
Can't comment specific to the 1200GS, but I had the SW Motech bars for my 1150R, sturdy and held up to a few minor tips. Great protection, easy to install though an extra hand is useful. Hardest landing on them was in a lot after a RTE. I put my foot down to stop and my ankle just buckled/rolled under me, dropped the bike on left as the throttle twisted - the effect was like screwing the bike into the pavement. Bars held up great with scratches you would expect but no other damage to mounting points or to the bike.
Maria
Retired Presidente
Maria V
Attack Ninja
Postby gastone » Fri Jan 27, 2012 3:46 pm
Gene,
I've got the Hepco Becker on my 1200. I've never had to take them off doing routine maintenance, including the valves.
Garrett
2007 G650xChallenge
gastone
Postby Deano » Fri Jan 27, 2012 4:47 pm
gastone wrote:Gene,
I like the HB's as well. Mostly because you can get them in black.
2007 R1200GS - "Lucky"
2004 R1150RA - REST IN PIECES
Deano
Mildly Retarded Gubmint Worker
Postby stevebmw » Thu Feb 16, 2012 8:39 pm
The Hepco-Becker ones are nice, and you might want to check out the Wunderlich bars, as well. Both offer the option of adding upper protection for your gas tank. Here's a link to our Wunderlich catalog:
http://www.wunderlichva.com/
And here's a direct link to the "Protection" part of the catalog:
http://www.wunderlichva.com/catalog/8-protection/index.html
If you have any questions, give Patrick a call and he can talk you through any of this stuff.
Steve Anderson
2002 R1150GS
Morton's BMW Motorcycles
Your HQ for GS fun!
Fredericksburg, Virginia
540-891-9844
steve@mortonsbmw.com
http://www.mortonsbmw.com
stevebmw
Board Viking
Postby ERC Scott » Fri Feb 17, 2012 11:38 am
When I rode a 12GS I installed Hepco-Becker bars. They did decrease cornering clearance a little, but only hit asphalt when encountering bumps during aggressive corners, and then only when I was lazy about body position :emb: . I'd install them again in a heartbeat. Scott
Postby Chiba » Fri Feb 17, 2012 12:08 pm
ERC Scott wrote:When I rode a 12GS I installed Hepco-Becker bars. They did decrease cornering clearance a little, but only hit asphalt when encountering bumps during aggressive corners, and then only when I was lazy about body position :emb: . I'd install them again in a heartbeat. Scott
Being the current owner of his former R12GS, I can say the Hepco-Becker crash bars are good :D
Postby toolman_57 » Sat Feb 25, 2012 12:44 pm
I installed the SW-Motech bars on my 08 GS. So far I've adjusted the valves and replaced the plugs without having to mess with the bars. No drops yet (knocking on wood). Let me know if you'd like me to email some pictures.
2013 K1600GTL (went on a diet)
2008 R1200GS (was eaten by the 1600)
toolman_57
Postby Genen8kua » Sun Mar 18, 2012 3:05 pm
I ended up going with the SW-Motech, which seemed a good value for my needs. Altrider makes bulletproof gear, but bars have to come off for every valve adjust. I ordered them before reading Chiba's post - that bike has certainly given the bars some good testing opportunities!
As I did my searching, I read some cautions about mixing crash bars with the plastic valve cover protectors, on the theory that in a tipover the bars could flex into the protectors leading to damage from the very things you've installed for protection. these both installed pretty close to my BMW aluminum protectors, but I'm confident that the Aluminum protectors can come off for maintenance without needing to remove the crash bars. To my eyes, it looks as if any deflection of crash bars into the BMW protectors will apply force where the protectors have potential to flex, so I'm not really worried about that. It's a bit of a belt-and-suspenders setup.
They nicely attach to the engine and frame and the cross-bar between the two and in front of the engine should help (and shouldn't be an excessive impediment to wrenching).
Left
Left Installed 400.jpg (77.53 KiB) Viewed 7273 times
Right
Right installed 400.jpg (41.93 KiB) Viewed 7273 times
The added benefit of having crash bars is that they provide a nice handhold for when I want to bend over to check the oil sight gauge without kneeling down on the garage floor. :)
Twisted Throttle had a good price and very promptly responded to my compatibility question, including their having a quick back and forth with SW-Motech.
The marketing copy said that the grey color goes well with the 1200GS frame, and that's correct - being a bit darker and a bit less silver in tone, they go fine with the bike but don't match. But they are crash bars, after all.
