redman wrote:rm,
your welcome to use my 36mm socket
your also welcome to use my impact if you need it
Tanks, got a 36 mm on order and a 25 inch breaker bar, I may have to see about getting Qaun's armature shop to grid it down though, they should have the equipment I imagine. I may try my manual impact driver before using the breaker bar and just hope the threads aren't frozen to the inside of the tubes, otherwise well...
Now if you're talkin and air impact tool that might do the trick, been soaking the cap threads in a liberal spray of WD40 every time I'm the garage cursing Lap. ( A friendly, albeit sincere curse, you understand )
worst case I guess is cutting the upper triple tree pulling the lower slider off and getting the steering stem out by sliding it down the upper tubes at which point I might as well replace the whole front end with something that has better twin disks. But that's not an expense I planned on right now.
Fromerly MR. MonkeyButt now Mr.
Breezy-Butt!http://roadrunes.com"Everyone is entitled to his own opinion,
but not his own facts" - Daniel Patrick Moynihan
