Hi,
My 91 K100RS has developed an odd lighting problem. At around 4000rpm the entire lighting system begins to flash intermittently, getting worse as I rev past that point. I've had a large part of the sys apart and the relay seems fine, no bad plugs or bare wires evident, and no loose bulbs that I can find. I've begun to suspect it's the relay that shuts the elecs down when the starter switch is pushed. Or the bulb check module, though I don't really know what that does, other than alert you of a bad bulb. It is difficult to reproduce in the garage as I don't like to rev it that far up on the stand for long.
Any ideas?
Drew
