VaSteve wrote:Is the existing garage a 2 car type? The drawings make everything look huge. When I saw the photos, 12x16 doesn't seem that big either. Is my perspective mixed up somehow?
Are you notching the floor for the lift?
JimVonBaden wrote:The existing garage is a 20X20 exterior size. The Extension/workshop is a 12X16. Neither big, but even the extra 192 square feet is pushing the city code size.
I nixed the lift notch. The cost was too high since I would also have to buy a scissor lift.
mlytle wrote:JimVonBaden wrote:The existing garage is a 20X20 exterior size. The Extension/workshop is a 12X16. Neither big, but even the extra 192 square feet is pushing the city code size.
are you bumping against the limit that additional buildings can't be more than 50% of the sqft of the main house? (fairfax county code) you can bypass that by building a covered walkway from house to garage. then it is an addition to the main house, not a separate building.
that does not help if you are dealing with a coverage percentage of the lot size.
i went through this challenge when i added my shop addition...it was not a separate bldg.
mlytle wrote:So if the garage was connected to the house would it still be subjected to the limit since it was not a separate structure?
mlytle wrote:an "attachment" can be as simple as a covered walkway. that is what i have..about 25ft of it. it made a huge difference in what i could do when i added a shop.
a neighbor used same idea, but only did a pergola type structure between house and garage. meets code for attached addition.
Users browsing this forum: No registered users and 18 guests
