Moderator: BMWGirl
Bicyclist wrote:Interesting, someone else posted about rear pads worn early recently. I wonder whether it has anything to do with linked braking?
BchrisL wrote:So the front is linked to the back , but not the other way around, right (2003 R1150RT ABS)?
Chris
twinsig wrote:I installed some EBCs last night, new to BMW 02 RT, found that the caliper pin on front (bracket/base) isnt freeing up as is the rear pin. Im not referring to the pin holding the pads but the guide pins for the caliper movement.
Question: Is it possiblt to disassemble the caliper and replace or clean/lube the pins?
Users browsing this forum: No registered users and 0 guests
