So my wear indicator finally tells me I need new pads. Indeed it's accurate....The interior pads are worn lower than the exterior, but both are pretty low.
$90 for the left set & $125 for the right set with the cable.
To save some coin, I decided to go with the OEM $125 set with the cable on the right side, but chose $39 EBC set for the left side.
I should be ok....right??
