eap wrote:BMWGirl wrote:Okay - I updated the first post with dates, tentative dates and places. I need to confirm a couple of dates.
Also - Please send me some ideas for "themes" The first tech day at Mortons will be the Suspension theme - Keep in mind, you can do any work you want (with reasonable time of course) but if you have any suspension concerns, this is the time to bring your bike down!
I will also have....
1) How to change your oil...
2) Tire changing - tips and tricks...
3) Reading the GS911
Any other suggestions for themes of the tech days???
Thanks!
Tech Tina
good themes Tina - you might be able to double up on some themes: e.g.) Include transmission oil with oil change
Here are some other reoccurring needs:
-Tire Changing (with side bar on tire plugging and ‘pick up your bike)
-Valve-adjustments
-F-series overview (oil and valves, chain adjust)
-Break shoe replace/caliper rebuild
-Clutch and Brake fluid flush/change
-throttle body sync
EXCELLENT SUGGESTIONS, ED!!!! Wow - I needed help with ideas - thank you!!
