Flashing ABS light again!!!
Got a Tech Question?
Moderator: BMWGirl
Postby thechainreaction on Sat May 19, 2012 4:21 pm
Okay so I just get the rubber back underneath me after not riding for 7 months and here I am again in the third year since I bought the 97 R1100RT from Mortons and this is now my third battery and the flashing lights from hell are back again. The last time the reset worked for a while and now another $150.00 battery and and the reset will not work , the same crap. Sell it?? Blow it up?? Bury it?? I love the bike but I just cant stand know that one of the greatest safety features (the ABS) isnt working especially after the flight I took last year off the bike ant VIR( and yes it worked then and passed the safety check before riding on the track. Does anybody out there have any ideas? Thanks Bill T #-o
1997 R1100RT
1969 Triumph Bonniville
1976 Honda 360T
thechainreaction
Re: Flashing ABS light again!!!
Postby biometrics on Mon May 21, 2012 9:23 am
Sounds to me like you have a current drain taking down the battery when you are not using it... (A radio? Tape or CD player? GPS, Phone charger, intercom, etc.?)
Start with a freshly charged battery and get yourself a current meter and check to see if you have a electricity leak when the bike is turned OFF, and if you do, then start pulling fuses one at a time until the meter tells you ZERO current.
If you don't have a current leak, it sounds like you purchased a bad battery, or it was not fully charged when you parked it 7 months ago... Do you use a battery tender when you don't use the bike for extended periods?
biometrics
Postby Genen8kua on Mon May 21, 2012 9:35 am
Hi Bill.
Biometrics has good advice on the low voltage fault, it is possible for a new battery to be a bad one. Are you sure it's a low voltage fault? That one should not require a reset - it clears itself.
Check the codes. Before you do a reset.
The low voltage fault can happen with a low battery & can be confirmed from the saddle if you do the rolling restart - see Anton's site and click on the ABS Faults article under brakes (you have an 1100RT, so you have the early ABS2 with the three pin diagnostic connector). The rolling restart is described under fault 5 - low voltage. That may not be the fault you have, so replacing the battery won't necessarily help. If it is actually just the low voltage fault then you need to problem solve your battery, possible current drains as Biometrics mentioned, charging system and the connections between them all and the ABS/Motronic unit. Since your bike sat a bit, cleaning these up could help - look for corrosion at the starter solenoid too - if there's resistance at that connection, there will be more voltage drop as the starter spins and thus more chance of the error.
This is all assuming that you've a low voltage error. Does it blink appropriately when you turn the ignition on (both flash together) and then switch to alternating after you start the bike? If no, then you have another problem and not the just the low voltage problem.
Again, check the codes:
Read Anton's pages and go to the IBMWR Oilheads tech articles, and download the R11xx maintenance manual. Worth having, regardless! Detail on the ABS is found around p 71. & this is the source material for much of Anton's. Only part that's any challenge is the test equipment - you can make your own with a 12V led or a 5v LED and a resistor, OR use an old analog voltmeter if you or someone you know has one (really, really easy and way cheaper than the GS-911 you'd need for a 2005+ bike). Follow the procedures and read the codes. Then get back to us when you have more information. You can use your new (or existing) test equipment to also check the codes for the Motronic unit.
I sure wouldn't give up on the bike without first reading the codes and then making efforts to repair whatever the trouble is. If it's a persistant low voltage fault in spite of a good battery and charging system, I'd start on a search and destroy mission for corrosion, loose contacts and loose and or corroded grounds. Other codes may point you in other directions.
I have an old analog voltmeter if you and the bike are in the Ellicott City area, but a trip to Radio Shack might be more convenient to you! Good luck.
Users browsing this forum: No registered users and 4 guests
