Lube Splines
Got a Tech Question?
Moderator: BMWGirl
Lube Splines
Postby Belizer on Tue Jan 24, 2012 6:13 pm
Plan on lubing splines on my 2001 1150 GS. Is there a specific lube that is best to use. What rated heat gun is needed for the job - will a cheap 1500 watt unit work.
Thanks
Bob
Belizer
Re: Lube Splines
Postby Janitor on Tue Jan 24, 2012 7:07 pm
As for the lube, I use "Honda Moly 60 paste" it is highly recommended and works well.
But I have 2009 R1200GS and didn't need a heat gun to get at the lower splines, I don't know the procedure for a 1150 GS.
Ride well,
Greg
2009 R1200GS The Coffee Racer
wa alaikum salam GS-em
Janitor
Undercover Logger
Re: Lube Splines
Postby JimVonBaden on Wed Jan 25, 2012 12:50 am
Now available, the 2010+ Camhead Video! Click here for other BMW Maintenance and Repair Videos!
This might be a good time to take a long look in the mirror, and not flinch!
Re: Lube Splines
Postby T.Wesley on Wed Jan 25, 2012 9:33 am
Janitor wrote:As for the lube, I use "Honda Moly 60 paste" it is highly recommended and works well.
I agree w/the Moly 60 - great stuff!
The 1200s have a different way of connecting the final drive than the 1100s/1150s. Definitely need a heat gun for the 1100/1150!!
Between the Spokes Editor - PM me with story ideas!
This is a motorcycle club, not the United Nations --Wild Pig
Iron Butt Magazine - not just for LDR!
T.Wesley
Re: Lube Splines
Postby ERC Scott on Wed Jan 25, 2012 11:43 am
Does BMW still make shaft-drive bikes? :lol:
Seriously, a few years back Paul Glaves in his MON tech column recommended mixing Honda Moly 60 in 1:1 ratio with Wurth Sig 3000 spline grease. I don't recall the specific rationale. Also, some riders advocate using Guard Dog's GD-525 Moly Grease. I'm not certain that (similar to engine oils, etc.) any one moly grease is all that superior to its competitors. Scott
2011 F800R Motorsport
2011 990 SMT
Re: Lube Splines
Postby T.Wesley on Wed Jan 25, 2012 3:10 pm
ERC Scott wrote:I'm not certain that any one moly grease is all that superior to its competitors.
I think you're probably 100% right on that.
T.Wesley
Re: Lube Splines
Postby Wild Pig on Wed Jan 25, 2012 8:40 pm
And most of them made by the same company.
04 1150 RT
07 1200 GS
"You pass through places, and places pass through you."
Wild Pig
Frequent Oinker
Re: Lube Splines
Postby guitardad on Wed Jan 25, 2012 9:36 pm
I used a cheapo Harbor Freight heat gun on our R11xx bikes, when pulling the transmission. It works, but be patient.
Chaz
'02 K1200RS - "Sonic"
'79 R65 - "Hans"
guitardad
Original Oilhead
Re: Lube Splines
Postby Chris B on Tue Feb 07, 2012 9:20 pm
If you're REAL careful not to pull the front 1/2 of the drive shaft out too far [-X , you can pull the arm with the final drive attached & dispense with the heat gun. #-o
Chris
"Those that would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety"
Benjamin Franklin
Chris B
Re: Lube Splines
Postby Bicyclist on Wed Feb 08, 2012 12:21 am
ERC Scott wrote:Does BMW still make shaft-drive bikes? :lol:
I think the rationale was that the carrier in the Honda grease dries up too soon and that the mixture with Wurth stays greasy longer. (Or some such.)
George
Meddle not in the affairs of dragons
Bicyclist
A.K.A. SANTA!!!
Re: Lube Splines - Update
Postby Belizer on Wed Feb 08, 2012 10:35 pm
Thanks everyone that provided input. Wes offered to help with the FD spline lube. Since the GS has 45K miles, I decide to take it to George at Uber and had him pull the trans to lube both splines. They were both dry, but not damaged.
More importantly, the slave cylinder was corroded, even though I change the fluid every year. I had a similar situation 40K miles ago and caught it in time them too, so the spline lube job caught a bigger problem that would have been costly.
Back on the road in just a few days and the $500 was worth it. Ready for the next 50K
Thanks
Bob
Belizer
Users browsing this forum: Google [Bot] and 1 guest
