Deano wrote:The top two holes should match up. That's all I use. Otherwise, apply a drill?
DogHouse wrote:Deano wrote:The top two holes should match up. That's all I use. Otherwise, apply a drill?
Right, the top two should match up. Having said that though, I had to finagle mine a bit
MABSTER wrote:DogHouse wrote:Deano wrote:The top two holes should match up. That's all I use. Otherwise, apply a drill?
Yep, you'd think that they'd match but they don't. Off by about 1/2 inch on both sides. All the advise on tool usage is about what worked. I bent the crap out of the bracket that came with the bike so that the plate would fit. Looks fushiizzzle.........but it works for now.
DogHouse wrote:MABSTER wrote:DogHouse wrote:Deano wrote:The top two holes should match up. That's all I use. Otherwise, apply a drill?
I'll take a look at it Friday morning
kleks wrote:Maria V wrote:I used a drill.
Ouch.
Kleks
Dough Boy wrote:Ha! You anal-retentive BMW owners! I use zip-ties.
Blaster229 wrote:If you turned bikes the way Dan does, you woudn't worry about any stooooopid brackets!
Return to Tips, Tricks and Links
