R1100RS Project.
Re: R1100RS Project.
Postby JimVonBaden » Mon May 11, 2020 1:07 pm
SS Brake lines are in, about a week from Italy. $80 delivered. Great deal considering the Galfer or Speiglers are $200.
Seem to be nice quality too. https://www.carpimoto.it/en-US/12031_10 ... -93-01.htm
Tires in too, because the old ones are OLD, despite lots of tread:
I also started reassembly:
Postby JimVonBaden » Fri May 15, 2020 6:57 pm
Got part way done today. Took off the wheels, cleaned them and realized I couldn't just clean the,. Demounted the tires, sanded and painted the wheels. Remount tomorrow, then the brakes.
Repainted the outdoor bar in a nicer pair of colors. The original matched the house, but looked silly by the fance.
85° and the flowers were happy!
Postby JimVonBaden » Sat May 16, 2020 8:52 pm
Not much done on the bike today, the weather was too nice. After the wife and I got back home, I installed the metal valve stems on the wheels. Note that the weight isn't enough to pull it to the bottom. I also tumbled and painted the front wheel rotor bolts.
Postby JimVonBaden » Sun May 17, 2020 11:52 pm
Refreshed the calipers today. They were rusty and nasty.
Jim :cool
Postby JimVonBaden » Tue May 19, 2020 9:10 pm
Some photos from the seal change. I did it dropping the fork leg, since I had the wheel off, and from the top, just for fun.
Changed the brake lines too.
Tomorrow the rear line and flush/bleed the brakes.
Postby JimVonBaden » Thu May 21, 2020 11:32 pm
Not really much done. Painted the wheels, cleaned and lubed the calipers and loosely reinstalled them, and mounted the wheels.
Postby JimVonBaden » Fri May 22, 2020 6:40 pm
Installed the rear caliper on the R1100RS, then flushed and bled all the brakes.
Tossed on the lower fairing just for incentive to finish it!
Postby jcabiles » Fri May 22, 2020 7:53 pm
Shouldn’t the front wheel be mounted in the other direction? The way the gutters are oriented on the tire, it would be forcing water to the center and not to the outside.
Postby JimVonBaden » Sun Jun 07, 2020 7:35 pm
jcabiles wrote:Shouldn’t the front wheel be mounted in the other direction? The way the gutters are oriented on the tire, it would be forcing water to the center and not to the outside.
Nope, front is correct. The rear and front have a different rotational look.
Postby JimVonBaden » Sun Jun 07, 2020 7:37 pm
Finally got my new HF polisher in, so now I can complete the bike.
Looking pretty good, still needs wax.
Postby bdimon » Mon Jun 08, 2020 10:33 pm
Is the color impregnated all through the plastic or is there a veneer of color on the outside? If you polish too much, would you go through the color layer?
Postby JimVonBaden » Mon Jun 08, 2020 11:02 pm
bdimon wrote:Is the color impregnated all through the plastic or is there a veneer of color on the outside? If you polish too much, would you go through the color layer?
It is all painted plastic. The paint is getting pretty thin, as red tends to do.
Postby JimVonBaden » Mon Jun 08, 2020 11:03 pm
Fully assembled, looking pretty good.
Battery charging, needs TB sync and starter is sticking, so I will need to take it apart and clean it.
Postby Rick F. » Fri Jun 12, 2020 5:48 pm
Wow, what a transformation! The RS is looking really good.
The calipers cleaned up very nicely. Are you going to sell the old brake pads on eBay? :shock:
Keep up the outstanding work!
2020 Mercedes-Benz SL550
2013 BMW 335i convertible (sold)
2007 Aston Martin V8 Vantage (sold)
Postby JimVonBaden » Fri Jun 12, 2020 6:27 pm
Rick F. wrote:Jim,
Thanks Rick. It has been a fun project, except for the spiders.
Looks even better in the sun. Took it for a short ride today. Rides nice, but the ABS is flashing. I will try a reset tomorrow.
Users browsing this forum: No registered users and 9 guests
