R1100RS Project.
R1100RS Project.
Postby JimVonBaden » Sun Mar 29, 2020 6:01 pm
Another project, a 1994 R1100RS. I picked it up before Christmas.
Decided to shift directions since I can't take the Vespa parts out to get blasted and powder coated.
The R1100RS is in the garage and on the Kenda. Popped off the body panels and tank with 3 gallons of bad gas, popped in a good test battery, and it lights up and turns over with the unmistakable sound of at least some compression. This is a good indication that the 31K miles hasn't been too hard on it.
Overall the bike is pretty grungy, but actually in good shape:
The underside of the tank was as ugly as the top, but the pump looks OK.
Some crud and water in the gas.
I spot polished the bike to see if I can salvage the paint. Looks like it will come out good.
Now to order the usual service items. If it runs, then I will order tires and brake lines.
Re: R1100RS Project.
Postby JimVonBaden » Wed Apr 01, 2020 7:31 pm
More tear down for clean up while I wait on the service items to show up.
Postby JimVonBaden » Sat Apr 04, 2020 2:22 pm
Swapped out the fuel filter and sock on my 1994 R1100RS. Kit from www.beemerboneyard.com .
Cleaned a ton of mold off the bottom of the tank:
Sanded the rim of the fuel plate to smooth off the corrosion, then used the BBY O-ring kit to install it in the tank.
Once all together I installed it and tried to start the bike. No go, no fuel at the injectors. I checked the pump and it was flowing at key turn-on, but nothing when cranking.
This is generally the HES, so off it came. Damn spiders are everywhere on this bike.
The pins were clean, and it all looks OK, but now I need to test it.
Postby JimVonBaden » Sat Apr 04, 2020 6:07 pm
@GS Addict pointed out that my HES wiring looked melted. Sure enough it is:
So, I decided to polish the paint since I couldn't start the bike:
No wax yet, I need to spot polish more, and the main fairing.
Postby Rick F. » Sun Apr 05, 2020 10:51 pm
Wow, what a difference! I never would have believed it.
Looks like a fun project, and I'm pleased to see that you're rescuing (yet) another BMW motorcycle. Good luck!
Postby JimVonBaden » Mon Apr 06, 2020 2:36 pm
Rick F. wrote:Jim,
Thanks Rick. It is definitely better, though I want to do another round of polishing.
Postby bdimon » Fri Apr 10, 2020 5:53 pm
I'm amazed that you did not have to paint the bike. I would not have guessed that could be polished out. Is the color impregnated in the plastic or a paint layer on the surface?
Postby JimVonBaden » Fri Apr 10, 2020 6:53 pm
Cleaned and polished the turn signals and tail lights of my project R1100RS. Like the rest of the bike, they were nasty. Came out nice.
Finished polishing the rest of the bodywork. It looks really good in photos, but the tank is still a bit dull. It will go round two polish, then all will get two coats of wax.
With the Corbin seat from BBY.
More proof that someone let the bike run at idle for an extended period.
Postby JimVonBaden » Sat Apr 18, 2020 1:30 pm
Added some lift wheels to my Kenda lift so I could load the bike in the garage, then roll it into the workshop with the bike on it.
The lift wheels worked perfectly. Painted them, then rolled the RS onto it in the garage, then rolled it into the workshop. It even went over the beveled 1/2" lip. Created an oil catcher from a paint pan so I could pull the valve covers. Works great.
Postby JimVonBaden » Wed Apr 29, 2020 3:41 pm
Progress. Sanded, sprayed with rust inhibitor, and painted with satin black. Looks nice.
More importantly, I received the rebuilt HES and installed it. Success, the bike runs, and it runs nice!
Postby JimVonBaden » Thu Apr 30, 2020 9:18 pm
FD fluid changed, was very clean.
Rounded off the 13MM hex for the trans drain. :baldy
It is rusted in.
These are a particular bitch to get out. Hard to weld on a bolt, hard to drill.
Postby JimVonBaden » Mon May 04, 2020 7:25 am
Oil and filter on the project R1100RS:
The oil was dark, but no burned smell.
Changed the alternator belt:
Tumbled and protected some bolts for various places:
More to do:
Installed the injectors with SS bolts:
More overheated engine evidence:
Next, rust correction:
Postby JimVonBaden » Mon May 04, 2020 8:44 pm
Drilled and tapped a front fender hole:
Installed head guards with refreshed bolts, then cleaned header.
Cleaned the swingarm, final drive and some of the rear wheel.
Cleaned and polished the gauge cluster. Came out nice except the inside of the tach. Funny how the tach and speedo are not equally faded.
Lights work great!
Received the fork seals and dust seals. Nice for the price of $21.
Little by little it is coming together. Tires and SS brake lines on the way.
Postby VaSteve » Tue May 05, 2020 4:38 pm
You sure put in a lot of work even before being sure it ran, no?
Where do you get these terrible condition bikes? Must have been cheap to be worth your while? (Of course I'm projecting my values on it.... :) )
2004 R1150R Rockster
Past (1980 R65)
VaSteve
Postby JimVonBaden » Mon May 11, 2020 1:06 pm
VaSteve wrote:You sure put in a lot of work even before being sure it ran, no?
I was messing around waiting for the HES to arrive, so yeah. Besides, if it wasn't any good, parting it would be better with clean and nice looking parts.
Yes, very cheap, $0.00. :lol:
