ABS fault '09 R1200GS
Postby dcgsrider » Sat Jul 13, 2019 9:23 am
Key-on, engine start. "Brake failure" light comes on solid and stays that way for the duration of the ride--it never flashes, as in the "normal" diagnostic procedure. It's sensing a fault in the system, even before wheels are rolling, which I understand is when the system checks the wheel sensors.
I guess I need a GS-911 to pull the codes. Odd thing is I've only ridden it a few times since changing the gear oil in the final drive--and then the fault code displayed. Could be just a coincidence, but I don't like coincidences...
Re: ABS fault '09 R1200GS
Postby thanatos1224 » Sun Jul 14, 2019 6:53 pm
The club has an old version of the GS-911 :-)
Postby eap » Tue Jul 16, 2019 3:14 pm
Also, take a look at your sensor rings on the wheels to see if they're physically gunked up or even bent.
Postby bdimon » Tue Nov 12, 2019 9:27 pm
dcgsrider wrote:I guess I need a GS-911 to pull the codes. Odd thing is I've only ridden it a few times since changing the gear oil in the final drive--and then the fault code displayed. Could be just a coincidence, but I don't like coincidences...
I have the GS-911. When do you want to meet up to get it?
Postby dcgsrider » Sun Nov 24, 2019 1:41 pm
Thanks, Bruce. I pulled the rear wheel and the reason for the fault became instantly apparent. The wire to the rear ABS sensor had come loose, rubbed on the rear wheel flange, and was eaten completely through. The replacement part was ~$150.
