Valve Stem Change.
Valve Stem Change.
Postby JimVonBaden » Fri Jul 08, 2016 4:19 pm
Not really all that worth a pictorial for most, but some might find it useful, and for some reason, many years ago, I took this set of photos.
Of course the tire needs to be at least half off the rim, though it is possible to do it just breaking the bead on a wider rim. I used a standard stem, but you could also use metal stems as well. I used RUGlyde tire lube to lube the stem, but nearly any lobe, even hand soap, will work.
So, with no more words needed:
Metal valve stem:
Re: Valve Stem Change.
Postby Chris B » Tue Jan 17, 2017 3:36 pm
Nice pics!
I'd like to mention that it's CHEAP insurance to replace the rubber ones every time you replace the tire. I went to check the pressures one day on my K1200LT @ work during lunch only to find the rear tire flat because of a cracked/split valve stem. Luckily I had the resources there to replace it quickly within my lunch break. Would have been a real problem if I hadn't found it until the end of the day.
JM2CW
Chris Barritt
"Those that would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety"
Benjamin Franklin
Chris B
Postby mlytle » Tue Jan 17, 2017 8:18 pm
nice pics Jim. agree, cheap insurance. i have had valve stems crack also.
Marshall
92 K75s
94 K75s
09 K1300s
mlytle
Postby Rick F. » Wed Jan 18, 2017 6:49 pm
Jim,
Nice DIY--thanks!
It somehow reminds me of one of my summer jobs back during my college days. I worked in a gas station, changing, repairing, mounting, and balancing tires among many other activities. One night, after a really long and tiring day, a couple of good ol' boys brought in a large pickup truck tire and asked me to just dismount it from the wheel. I knew it was going to be hard to break the bead on the tire--we didn't have a hydraulic tire machine, just one with good old-fashioned levers--but this one was incredibly stubborn, and I tried and tried without success. Eventually one of the guys said, "Ain'tcha gotta let the air out of it first??"
Yep, I was so tired that I'd completely forgotten to take the valve stem out first! It wasn't the only dumb thing I did at the station that summer, but fortunately you learn quickly when you're 19.
Postby JimVonBaden » Mon Jan 30, 2017 3:36 pm
It is really a no brainer to get with metal stems, even in your cars if you do not have TPMS.
Users browsing this forum: Google [Bot] and 1 guest
