2004 11550 GS "stuttering" under acceleration
Postby Slider » Sun Mar 20, 2016 3:21 pm
my GS "stutters" under load regardless of gear at higher rpms. it feels like it is running against the rev limiter. typical "stutter" is between 4500 & 6500 rpms.
fuel is good, new fuel filter & hoses, new plugs.
so whiskey, tango, foxtrot?
thanks for the feedback.
Slider
Re: 2004 11550 GS "stuttering" under acceleration
Postby Chiba » Sun Mar 20, 2016 5:23 pm
Check the ignition coils.
Postby JimVonBaden » Sun Mar 20, 2016 6:47 pm
Likely one of your stick coils is bad. You can unplug them one at a time until you feel the engine change the way it runs. That will be the bad coil.
Postby Slider » Tue Mar 22, 2016 8:50 am
thanx all, I'll try that again, first check of the "sticks" did not change anything.
ciao
Slider
Postby Slider » Wed Apr 06, 2016 7:24 pm
New "sticks" from Bob's did the trick, runs like "stink" as they used to say in the old days!
Slider
Postby Genen8kua » Sat Apr 16, 2016 3:59 pm
JimVonBaden wrote:Likely one of your stick coils is bad. You can unplug them one at a time until you feel the engine change the way it runs. That will be the bad coil.
Jim, isn't it the other way around (bad coil is the one where the engine does NOT run worse when it's unplugged)?
Looks as if slider replaced 'em all as a set (which is what BMW recommends) but that has always struck me as hard on the wallet for an item that may or may not fail. Thoughts?
Postby JimVonBaden » Sat Apr 16, 2016 7:54 pm
We are basically saying the same thing.
Users browsing this forum: No registered users and 15 guests
