kioolt wrote:My question here is it necessary to heat the disc bolts to remove them? I bought a wheel on ebay that will come without discs so I will need to remove the ones from my old wheel. Can the bolts be reused? What should they be torqued to?
kioolt wrote:I hit a huge pot hole today and it bent my front wheel. It hit so hard that the front fender went up into the bottom of the nose fairing hard enough to make the paint crinkle off. My right mirror also fell off, which broke my multivex mirror. My question here is it necessary to heat the disc bolts to remove them? I bought a wheel on ebay that will come without discs so I will need to remove the ones from my old wheel. Can the bolts be reused? What should they be torqued to?
