Ok, so a few months back the ABS module on the GS croaked. Finally got around to getting it rebuilt by Module Master (good quick service, and 10% the price of a replacement btw). Got the unit in the bike and am putting the fluid back in starting with the rear circuit. Figuring I needed to do a change anyway, I emptied out the circuits before taking the module out of the bike.
Filled the res and began pumping the brake pedal as usual for a regular bleed. Got about 1 refill into it and now can't build pressure and, pump as I may, the level won't go down in the res. Checked all the connections, no leaks. Put the miti-vac on, will pull a vacuum but doesn't seem to pull fluid. Spent the better part of two beers trying to reason it out, and another beer and a half searching the interwebs for an answer. Lot's of posts on those god-forsaken abs servo brakes, but....
Whattami missing, something obvious?
Not being patient enough and need to pump the pedal 5000 times instead of 2500?
Anyone refilled an entirely empty circuit have any tips?
