Page 1 of 2
FYI - 2008 K1200S Fuel Sending Unit failure - known issue
Posted:
Fri May 21, 2010 1:16 pm
by Yellowjacket
FYI: I talked to both Bob's and Morton's service departments regarding my fuel sending unit failing around the 2 year mark. This is a known issue which has been reported most widely by the 2005-2009 K1200x owners in the United States. Apparently the alcohol in the gas mix is causing the strip sensor to fail. BMW has not announced any workaround or fix. The fuel warning light still works. I will replace this unit towards the end of my bike's warranty. I depend more on the Trip Meter and fuel warning light anyway.
Re: FYI - 2008 K1200S Fuel Sending Unit failure - known issu
Posted:
Fri May 21, 2010 1:53 pm
by ObiWan
What is the exact issue you called about?
Posted:
Fri May 21, 2010 2:06 pm
by Yellowjacket
The issue I called about is my fuel sending unit failing around the 2 year mark. The fuel level sensor is made of (among other parts) a rubber (?) strip. It turns out that this issue has been discussed on other forums as well.
What happened to a simple metal floater and a metal sensor?
Posted:
Fri May 21, 2010 6:04 pm
by Unity
Yellowjacket wrote:What happened to a simple metal floater and a metal sensor?
Moz, you are sooooo old-fashioned!
(A regular Luddite.
Posted:
Fri May 21, 2010 6:29 pm
by Yellowjacket
Unity wrote:Yellowjacket wrote:What happened to a simple metal floater and a metal sensor?
(A regular Luddite.
Hear, hear, from the Luddites!
I could easily shake the 50-100cc bikes to see if any gas sloshes in the tank. No sensors required...
I work with cutting and sometimes bleeding edge technology, yet I often use low tech to back up high tech. I suppose the engineers in Berlin have not included alcohol as a possible wear and tear factor in their design requirements. To think that Germany has been on the forefront of green technology. I hope the cost of the warranty repairs over the last 5 years will induce BMW to take a look at the sending unit design albeit a low tech one
Posted:
Fri May 21, 2010 9:34 pm
by Bicyclist
My '67 Suzuki X6 had a clear plastic tube attached to the tank. A glance would tell you how much fuel you had. Hard to beat for simplicity.
Posted:
Fri May 21, 2010 10:48 pm
by ObiWan
I have heard others mention the issue about incorrect or flat-out inaccurate readings on the fuel gauge. With no "reserve", you walk a time or two for fuel and you learn that the bike will go 250 miles max on a tank, so better stop around 225 or so...
Is that the problem you refer to?
Rubber sensors?
The fuel pump on my 94 K1100LT nearly died. Got a new one a Napa, but not exact. Shorter. Meant that the "indicator light" was too late. So, I learned the mileage on that one too. Also learned to "lean to the left" for the pickup to get whatever fuel was left... It had the metal plunger for fuel level...
Meanwhile, my 06 K12GT has no issues with the sender, my indicators seem to work fine... (Now where is that wood to knock on?)
Posted:
Sat May 22, 2010 3:11 am
by Yellowjacket
ObiWan wrote:...Is that the problem you refer to?
Rubber sensors?
Mine completely failed. You can find more info and instances of failure on BMW Super Bikes or BMW-K forums. The dealers have replaced quite a few of these units.
Posted:
Sat May 22, 2010 8:39 am
by ObiWan
Right, I am agreeing with you about the known issues, I just had not seen one FAIL to this point, that is all.
I am extremely lucky in that mine works fine. I am also somewhat cheap and have not owned a bike new enough to be covered under warranty until my current one. And even then I had only 1 month of warranty.
So, my personal experience has been to learn to fix it or live with it, whatever the problem may be.
You have an awesome new to you bike and it is a bummer to hear that it has problems, I am hopeful that you will get them all fixed under warranty.
I have just not ever had that luxury...
All of that said, thanks for the heads up, now if mine ever does fail, I know I have a recourse.
Posted:
Sat May 22, 2010 10:26 pm
by Yellowjacket
Roger that!
Posted:
Sat May 22, 2010 11:22 pm
by JimVonBaden
Moses,
IMHO the concept of 10% alcohol being the culprit is not that valid. There are dozens, maybe hundreds, of cases where these same type of strips have failed on the R1200GS Adv, and many did not use alcohol laden fuels at all.
IMHO, there is a design flaw. BMW may own up one day, but I wouldn't count on it.
Posted:
Sun May 23, 2010 7:16 am
by Yellowjacket
JimVonBaden wrote:...
Based on the riders' feedback it is looking that way... I am definitely not holding my breath. I got used to setting the Trip Meter on the GS and the Vic as a backup so it is an easy transition on the S. I plan on timing the warranty repair to get maximum coverage.
Posted:
Sun May 23, 2010 12:04 pm
by BchrisL
Bicyclist wrote:My '67 Suzuki X6 had a clear plastic tube attached to the tank. A glance would tell you how much fuel you had. Hard to beat for simplicity.
ARRG! MY '51 Piper Cub had a brass rod that protruded from the top of the tank to indicate the level of fuel.
Posted:
Sun May 23, 2010 1:07 pm
by Bicyclist
BchrisL wrote:Bicyclist wrote:My '67 Suzuki X6 had a clear plastic tube attached to the tank. A glance would tell you how much fuel you had. Hard to beat for simplicity.
What kept the water out?
Posted:
Sun May 23, 2010 2:02 pm
by Dan
BchrisL wrote:ARRG! MY '51 Piper Cub had a brass rod that protruded from the top of the tank to indicate the level of fuel.
lol, that's pretty cool.
We just used a dipstick with markings on it to indicate the fuel level on the Piper Seminole- and usually just eyeballed it up to "tabs" on the Arrow and the Cessnas.
